transamz9
Mar 29, 2016Explorer
RoyB wrote:
There is no real good reason changing out the trailer safety lights if you are trying to save DC Power on your trailer batteries. The Trailer safety lights run off of the truck start battery system not the trailer batteries...
These safety lights are DOT approved when the trailer folks built the trailer. The LED replacement bulbs/boards for the 1157 automotive bulbs may not be DOT approved to use for the trailer tail light assemblies. Using replacement LED lights for trailer safety lights may have to use a complete DOT LED Lamp assembly...
Since these lights are powered by the 12VDC truck start battery system you will not gain any useful trailer installed battery DC Power savings wise.
Something to check with DOT/DMV about at any rate...
Just my thoughts here...
Roy Ken
I run my lights on my 5th wheel when it's not hooked to the truck at the campground. It gives a good glow of light 360* around the coach and don't hurt your eyes like a lot of lights people use. By having all LED's they run cooler which cuts down on the bugs, and also it's not pulling near the juice from my converter. I also use the back-up LED lights on the back of the 5th wheel to clean fish at night. I do this by using the coach's power not the truck.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
