looked up that trailer and it seams kinda light for that size, but could be the materials they use. and if that is the case how well do they hold up? but only holding 3000 lbs does not give you much leverage. a full tank of water is going to be about 790lbs, now you only have a little over 2k lbs left. not sure what you ride or if you plan on putting toys back there but those can weight a lot too. I tow a 26' TH (total a little over 31') and it is over 1000 lbs heaver dry and has a gross weight of just under 11k. I would not think if towing it with a 1/2 gas truck, but people do it. I bet if you put that trailer on a scale you would get much different numbers. like everyone else said if you want that big of a trailer you need to get a better truck. 1/2 ton v6 is not going to do it.
