Mont G&J wrote:
Your problem wasn't the e-z lube system, you apparently had four bad seals, or they wouldn't have leaked grease past a double lipped spring tensioned seal.
How does a person get four bad seals? Easy, a person pulling and reinstalling four wheel drum assemblies that doesn't know how to do it correctly.
The wheels were never pulled off until I took them off and found grease on the brakes. I did change the seals so if they go bad now it will be my fault. If you like the E-Z Lube go for it.
I will not take a chance on them again.
