DutchmenSport
Sep 01, 2019Explorer
Let's talk generators - again.
I'm still doing research on a generator for my 5er.
First off, "the boss" has decided that SHE does not want a portable unit, for the sole purpose of being able to run the air conditioner(s) in the 5er at any time, even while driving. Also, being able to power up the 5er at rest stops, events, and such without having to drag out something on wheel and wires.
My 5er is a 50 amp with 2 AC's and Residential refrigerator. I have no issues with the refrigerator, powered by a 1000 watt inverter, powered by 2-twelve volt batteries when off grid.
So, that has pretty much narrowed down my list to the Cummins Onan RV generators. My 5er is designed to fit a generator in the front bay:
And the two under consideration:
Cummins Onan RV QG 5500 Gasoline Generator
Cummins Onan RV QG 5500 LP Generator
One thing I'm not able to determine, especially with the gasoline version, is the fuel tank. Does anyone know if the generator itself has a fuel tank? Or does a separate fuel tank need to be installed somewhere in the 5er.
I have a portable generator I use at home, and it has it's own gas tank attached. Holds 2.5 gallons.
For those of you with a 5er, no doubt the generator is installed in the front bay. Where is your gasoline supply for the generator at (if you have one).
If you have LP version's fuel, no doubt it has to be supplied by an external tank somewhere. Did you just tap into your existing 5er gas lines, or install a separate gas tank/bottle. I always carry a 3rd - 30 pound propane tank with us in the pass through because we do use this camper in the winter (a lot) and wanted a back-up full tank, all the time.
Last question? Portable units are ruled out. Other than Onan, are there any other manufacturers that make an in-house RV generator, similar to the Onan. Or is Onan the only one "out there". If there are others, what are they?
Yes, I know these things are "pricey", but I'll deal with that once I get the logistics figured out.
Your experience is greatly appreciated.
