RoyBell
Sep 03, 2019Explorer
I rather have the Gasoline version personally. Easier to see how much fuel is left with an actual gauge. I would think you could get gasoline much easier than propane at any given moment. With 30 and 40 lb tanks you are limited to a refill rather than an exchange. I am only 37, but manhandling 30 and 40 lb propane tanks every time I go camping seems like an unnecessary chore to me.
Propane is less efficient than gasoline and costs more as well.
If propane is 1.1 gal per hour, for 48 hours of use you are using 52 gallons of LP. 1 gallon of propane= 4.2 lbs. My local joint is $1 per pound for a refill. 52 gallons x 4.2 lbs= 218lbs total. @ $1 per lb, that's $218 for 48 hours of generator use.
Gasoline version is .9 gal per hour, over 48 hours of use you use 43 Gallons of gas. Gas by me is currently 2.50 a gallon, so $86 in gasoline.
To extend that out, assume 400 hours of generator use for a year, which may be in line for a full timer?
Propane= $1848
Gasoline= $900
Another thought, if you only use half of your propane bottle, you still have to pull it out to refill it. If you use half of your gasoline, you can fill it up when you are filling up your vehicle.
The only downside of the gasoline version is gas doesn't last as long sitting idle. However, I never had an issue with gasoline if it's been treated for long term storage. This includes all my vehicles that sit for 5-6 months at a time over winter.
Propane= $1848
Gasoline= $900
About Fifth Wheel Group
