bowler1 wrote:
Thanks for your help on this. I snapped a couple of pictures when out this weekend that show the camper hooked up. The road I am parked on has a very slight incline but is mostly level. You can see that the camper is nose high, but I am not sure if this is considered to be "significant" enough to worry about. It appears I have plenty of clearance with my truck rails and the truck is fairly level.
The truck is an 18 Ram 3500 with 4600 pound payload. Unloaded pin weight on the trailer is 2500 pounds.
Matt
I think if you look at the door jam sticker the listed payload for your particular truck is less. My 2015 3500 4x4 Laramie SBCC Aisin is stickered for 3664. RAM chart list 3920.
For long boxes the numbers on the chart are 4330 for Aisin trucks and 4480 for 68RFE trucks. So your door just sticker for a Laramie in most likely several hundred pounds less. The chart shows no combination with 4600 lbs capacity.
