bandit86 wrote:
This trailer is going to see some logging roads with sections washed out, I want to get it high to keep from hanging up. I'm even thinking of mounting wheels to the frame rails front and back just in case
I can see the skid wheels on the rear of the trailer, but I'm not so sure about on the front of the trailer. If they make solid contact with the ground, then they're going to lift the weight, and therefore the traction off of your rear drive wheels even with four wheel drive. If you're in bad enough conditions for that, then you need all four wheels on the ground with solid traction.
Bill
