Boozecamp's avatar
Boozecamp
Lift process for removing all 4 tires
I want to buy 4 new tires for 5er. Want to remove all four tires/wheels, take them and the new tires to a mounting shop. I have hydraulic front landing gear and electric stabilizer jack system in rear. Can I lower front hydraulics to the ground, extend the rear jacks to grade, then raise front high enough to suspend all four tires? If not, can I support frame just behind rear tires and do the same. Ultimately, I need all four wheels removed to get new tires remounted. I want to avoid twisting frame so I think option one is risky, plus, I'll be putting about 12K lbs on the rear jacks. Any better suggestions? I am full timing and don't want to drag it to an RV dealer shop.
