dapperdan
Feb 07, 2015Explorer
If you can, leave your truck hooked to the trailer. That way your trailer doesn't "shift" on you while you jack it up.
Place your jack directly under axle close to bake hub as you can. lift just enough to be able to remove tire. Place jack stand or wood blocks under axle as close to hub as possible. Do NOT have jack stands or blocks in the middle of the axle as you will bend your axle! Repeat this process on all your wheels and you should be to go.
IMO, I'd do one side at a time, it would be your safest way. Of course it means two trips to the tire store. Hope this helps
Dan
Dan
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
