taken
Jun 11, 2015Explorer II
Jodesi76 wrote:
hello every one I own a 2008 cyclone fifth wheel toy hauler with 3 axle under springs setup my. f250 has a 6" lift what I'm looking for is just 2" gain clearance from my bed rails the Spring hangers have two additional holes from where the shackles were set at the factory. So the question is has any one tryed moving shackles down to the lower holes on the hangers. My plan is to add sleeves in between the hangers to reduce flex do you guys believe this will work or will the stress on the hangers be too great on the hangers and welds thank you in advance
A very cheap bolt on solution is to get a Correct Track 2 kit for your trailer. It is designed to align your axles but as a side effect, it raises the rig exactly 2". Only about $350 and can be done with simple tools and a drill. If the lower holes give you the clearance needed, I'd start there though. If your worried about added lateral forces, got with a set of MorRyde X-Factor cross braces.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
