Likes to tow wrote:
I would rather remove the blocks between the axle and springs on the truck!!
Trucks are made much higher now, I suppose it's some kind of marketing strategy to make the truck seem bigger, more powerful, more manly...etc?? There is no good reason for it in my opinion and if I were to replace my 05 Ram with a new truck this is what I would do immediately. These blocks of steel are removable. You don't have to take them all away, just remove enough to make the bed of the truck lower. I've talked to guys who have done it. The last thing you want to do is raise a trailer, especially a 5th wheel which is already very tall, and cause the center of gravity to be in favor of a roll over in high winds or in a surprise sharp curve. I think 4WD trucks have more blocks anyway to get extra clearance for off roading??!!
Don't listen to this nonsense. When you start changing the angles of the drive shaft and suspension, you're asking for trouble. Raising the trailer is sensible and done all the time due to the increase height of the newer trucks.
