craig7h
Dec 06, 2013Nomad II
I just finished doing work on the suspension system of my fiver. It required takeing both wheels off at the same time. I found that two jacks were needed as to not twist the frame. I also found for the standard bottle jack I needed to make a large foot print of 6x6es to feel safe while working around the unit. If you look close where your frame and underbelly covering meet you will beable to put a jack without much damage. I also did the work with the unit hooked up to the truck and landing jacks up.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 18, 2026
