greende
Dec 07, 2013Explorer II
Veebyes wrote:
For those lifting by the axle, the last time I looked axles are round. Round is not a good place to be lifting at. Things slip. Very easily. Best spot will be right next to the axle under the bottom spring leaf.
While you are correct in that you are jacking on a round surface, the other side of my trailer is blocked with my x-chock and the other wheel on the side I'm jacking is chocked traditionally. I have not experienced any movement with this system. IMO, an unstable jacking base is more likely to cause problems.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
