JIMNLIN
Dec 07, 2013Explorer III
I have a 12 ton shorty hyd bottle jack with a 10" base for soft ground for changing a flat tire on the road. At first I had a adapter made that slipped over the end of the jack and captured the axle/U bolt. It was ok but kept misplacing the adapter.
Now I have a steel channel welded to the top of the jack. It cradles the axle tube so no chance of anything slipping. I use this on the road.
At home if I'm working on all the hubs, I use both of my hyd floor jacks placed under the frame next to the farthest aft and farthest forward spring hangers and lift one side of the trailer at a time. I have piles of RR ties of all lengths or 5"x7" barn poles of different lengths I can use to block up under the frame. I angle each stack of blocks to each other which eliminates any chance the blocks to roll wile I'm under there.
I never leave a truck hooked to any of my trailers while jacking unless I'm on the road. Landing jacks can handle that end just fine.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
