laknox
Oct 15, 2015Nomad
06Fargo wrote:
Thanks Lyle. Yes - when we tow using our hitch extension (with the truck camper loaded) the ball is 36in back of the truck receiver - a 16ft tandem cargo trailer almost tracks in the truck's tracks around the parking lot.
The "Mr Truck review" video shows how the unit couples to the tow vehicle - draft loads are transferred at the end of frame couplers. The center receiver has a V shape alignment fitting.
Lots of interesting well thought out features...
I took a quick look on the Net last night and did find another tag hitch that looks to be much heavier than the Automated. Looked to have 20" wheels on it. It was different in that it appeared to have only one attachment point, yet the wheels steered. I don't know how beefy a single, center, connection would have to be to horse that around, but I suspect it would likely be =heavier= than the 3-point system of the Automated system.
Later: Just re-checked and it's called Add An Axle (http://www.addanaxle.com/). What it looks like they've done is to use a standard receiver hitch, with a vertical swivel-plate behind it to allow for rocking/twisting motion and, what appears to be, a parallel linkage between that plate and the dolly itself to allow for vertical motion. They're rating the base unit with a 7k capacity axle with hydro-disk brakes, but imply that different axle capacities can be had.
Even later: OK, I zoomed in a picture of the dolly and they =are= using a 3-pt attachment, but the outer 2 attachments are with =chains= and ratchet binders instead of a hard-mount like Automated does. Makes a =whole= lot more sense, now. FWIW, their web site is very basic, with small pics that don't zoom and one video that doesn't work.
Lyle
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
