Campinfan
Oct 22, 2015Explorer III
majorgator wrote:
I could agree that the outer arms on the Automated Safety Hitch provide a certain amount of sway control between the truck and the hitch. However, I do not understand how they can provide weight distribution (in the sense relative to RV's) with only the latching system.
Either way, if your truck is rated to tow, say, 14,000 pounds MAX from the "conventional" position, then that's the limiting factor. It doesn't matter how you shift the weight around. And while it is helpful to have another braking axle, the truck braking is designed (theoretically) for the weight of the truck and max payload. Trailers of this class being talked about for this hitch should have sufficient braking on their own axles.
Maybe its because they are taking some weight off the back axle and putting it on the "tag" axle of the hitch. I guess we would know if there was a weight/scale comparison of someone using it and then not.IT seem it would solve the complaint so many bring up on this forum...the limiting factor of a 3/4 tonner is the capacity. As long as your GVWR/CGVWR is under the limits, you have shifted the weight of the cargo capacity limitation.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
