ilvtravln's avatar
ilvtravln
Explorer II
Dec 08, 2016
Linoleun coming loose ????
In a narrow space between the shower and bath cabinet the linoleum is lifting up slightly, any ideas as how to reattach it? Thanks
  • I can't get under it so maybe stapling it down and using some trim might work. Thanks
  • rhagfo's avatar
    rhagfo
    Explorer III
    We had the same issue, we came across it when buying the Copper Canyon the Linoleum edge along the step up to the bedroom area was curling up, that and a drawer track issue got us an additional $500 off the price.
    I simply stapled down then put a $5 piece of oak trim. The drawer slide was a simple couple screws.
  • Would vinyl or rubber molding work for this problem?
  • On many units, the vinyl flooring is not glued down to the subfloor. Just stapled along the outer edge before the exterior walls are installed. Then interior walls, cabinets, toilet, bathtub and furnace grills also secure it. If it is curling up, then someone cut it shorter than it should have been cut.
  • We had the same type problem... we re-secured it with double sided carpet tape.
    Good Luck and Happy Camping
