Me_Again
Oct 07, 2013Explorer III
Beaker wrote:...that the square corner is gone from the plate hanging out of the 5th wheel overhang, as I cut it off at the same angle as the extended pin box.
Are you talking about the wings?
I am talking about the mounting plates that hang down out the trailer overhang. The pin box in my case has 4 bolts on each side that secure the pin box to the trailer. The rear of this plates hung down about 3.5 inches below the back end of the pin box, and would run into and damage the bed rails in a tight jack knife backing situation.
Trailer just happens to be in the front yard right now, so you get an up close up picture. I have the pieces in the trailer that I cut off, but this should help. I put lines into the picture where the plate use to be hanging down.
Angle iron is part of my pin box bike rack.
Chris
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
