Sounds to me like you have a 12 Volt issue. Even though you tried it with 2 brand new batteries, were the batteries fully charged? The jacks are designed to work on the 12 volts supplied by the batteries however they require batteries that are fully charged. (Specifically 12V automotive/marine/RV batteries with a minimum rating of 500 CCA, and/or at least 60 AH). Fully charged batteries should read 12.8 volts. if the read 12 volts, they are almost dead. What code did the leveling display show?
- mopargirl37Jul 16, 2025Explorer
We are good on the batteries, they were reading 14 volts. I am not sure on the code, I remember it did say aborted and timed out at some point.
- IB853347201Jul 16, 2025Nomad II
Yeah, I agree with way2roll's answer. The 14 Volts you are seeing is from the charger not the true voltage of your batteries. You need to unplug your RV, wait a day and see what each batteries true voltage is using a multimeter. If they have been charging since you installed them at the 14 volt rate, they must have been dead when you bought them (if they were new). Once they are fully charged your jacks should start working again on battery, as they should.
- way2rollJul 16, 2025Trailblazer
You reading them with a meter or the panel? 14V is the reading when charging and doesn't really indicate the at rest voltage. 14V while charging usually indicates the charge rate on a low battery. 13.5 would be a good charging rate for a healthy battery and 12.8 at rest for fully charged. You need to test them at rest/not charging and see what they read. My money is still on bad/low batteries.
- mopargirl37Jul 18, 2025Explorer
Sorry for the delay in replying, we traveled back home, the 5th wheel is in storage about 4 hours from us. The batteries at rest read between 12 and 13 volts. There has to be something with the charging also?? This is our 3rd set of batteries, I need to figure out what is killing them. When we purchased the unit they had installed new batteries and we had issues with the jacks and the batteries were dead after a week. Bought a second set, same issue. This is our 3rd set now, reading fine and still cannot do the jacks without hooking up the generator. So maybe I have 2 issues. We have a smaller 5th wheel that we travel in and we do not have any issues with this.
