mopargirl37
Jul 16, 2025Explorer
We are good on the batteries, they were reading 14 volts. I am not sure on the code, I remember it did say aborted and timed out at some point.
IB853347201
Jul 16, 2025Nomad II
Yeah, I agree with way2roll's answer. The 14 Volts you are seeing is from the charger not the true voltage of your batteries. You need to unplug your RV, wait a day and see what each batteries true voltage is using a multimeter. If they have been charging since you installed them at the 14 volt rate, they must have been dead when you bought them (if they were new). Once they are fully charged your jacks should start working again on battery, as they should.
About Fifth Wheel Group
