jsr21
Jan 19, 2016Explorer
It sounds like the voltage to the motors needs to be turned up. If your batteries are up and/or you're plugged in, the control box may need to be adjusted. The control box for the slide has little pegs that can be turned to increase voltage going to the motors. I had a bedroom slide on a Jayco Pinnacle that was doing the same as yours and adjusting the voltage at the control box totally cured the issue.
About Fifth Wheel Group
