mikewats wrote:
Need a new battery. I was thinking of a 12V Lithium battery. Not very familiar with them, will my AC/DC inverter 50amp with charging work or will I need a special charger for this type of battery? Any help would be greatly appericated
The battery seller will have the battery manufacturer's specs for best charging.
The manufacturer of your rv's power center/charger will tell you if it meets those specs.
Some equipment has a battery charging section that can be changed to a charger that meets the lithium battery specs, or may have settings you can change.
Low temps - LiFeo4 batteries can be damaged if the cells recieve charging voltage when they are below 28-32F. Probably most commercial "Group" type batteries include cold charge protection in their battery management system (BMS). Self heating batteries are available on the market that pre heat their cells when they are receiving charging current before turning on the charge to the cells.
The caution is for the temperature of the cells themselves inside the battery case, not the outside air temperature for 30 minutes at sunrise. Li batteries are sealed so you can have them inside your heated space if you want.
