Toolguy5
Jun 23, 2016Explorer III
We have about the same distance of pipe. But I don't have that problem. I usually flush thoroughly with water before disconnecting.
But I do have another concern. With the valves being inside the tank with a cable mechanism to open and close. If it ever breaks when it is closed how do you get it open.
So after you put the twist lock valve on do you still use your other valve or do you just leave it open.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 12, 2026
