aviator41
Jun 23, 2016Explorer
Toolguy5 wrote:
We have about the same distance of pipe. But I don't have that problem. I usually flush thoroughly with water before disconnecting.
But I do have another concern. With the valves being inside the tank with a cable mechanism to open and close. If it ever breaks when it is closed how do you get it open.
So after you put the twist lock valve on do you still use your other valve or do you just leave it open.
The new valve doesn't replace the function of any the original valves. it's just one last "line of defense" from anything that might be lurking in the behind the current cap.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 11, 2026
