ford_truck_guy
Apr 07, 2017Nomad
bpounds wrote:wls wrote:
I was reading this post/thread, and have noted some of you have put a waste gate on perminate, did you use the twist on gate, cut the tabs off the male end of the sewer pipe, where the cap or sewer hose connects on. Then just glue the twist valve on? My gate vale measures 3" ID, if I cut the tabs off, can I slide the valve on to be glued?
I would not call mine permanent. I just twisted it on as designed. But I was concerned that it could maybe rotate and be lost during travel. Probably would not, but it is rather large and heavy compared to the normal cap. So I placed a short sheet metal screw behind one of the twist-on ears, which you can see in the pic below. Easy to return to normal if I ever want to, but that valve ain't ever coming off by itself.
Great idea !! How did you seal it? with silicone, or is it short enough that it did not pierce into the inner wall>?
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
