ol_Bombero-JC
Nov 29, 2013Explorer
ByTheRvr wrote:
I have a bad back and the eu3000i is heavy so wherever it goes it has to stay there. We plan to buy a used unit so if it doesn't have a generator compartment I guess I'll have to lock it in the truck bed. Perhaps I can find a metal toolbox that is large enough to fit the generator inside. I had a eu2000 previously but it wouldn't run the AC. Thanks for the feedback.
Apparently some posters aren't following your posts..:(
Since you already have the 3000i -and- the trailer you purchase may *not* have a generator compt (which the 3000i won't fit in anyway) -
continue with the truck bed location..:C
It's no problem with a short or long bed p/up..
I keep my gen between the cab and the hitch - in my SB pickup.
Your tool box idea is fine - but think *INVERTED* tool box!.:W
You will never have to lift the gen in or out of the tool box, -and- the gen will also have adequate air flow for cooling and exhaust when in use (box removed)..;)
How to keep it from growing legs?
This sounds way more complicated than it is:
1. Cable lock (or other method) the gen in place in the bed of your truck. Only removed when (if) you wish to take the gen out of the bed for storage, winter, etc.
When you're not using the gen, #2 next - covers & "hides" the gen *AND* your cable lock.
2. Fabricate a "box" to be placed over (open end down) the gen.
The 'box' can be wood or metal. Obviously, metal would be better.
3. Decide on a method to lock the box *TO* the gen - which, without unlocking - means you (or a thief) are attempting to lift the generator underneath.
Since I have a Yam 2400is, this was easy - flat bar slips through two slots in top of the box and under the handles of the gen underneath.
Lock in the bar prevents it from being removed.
When you're ready to use the gen - simply unlock (and remove) the box.
If you planned (designed) well, it's not heavy.
(I can do that without getting in the bed)
BTW - when covered - it's conjecture what's underneath!.:?
You can add a bit of "disguise" if you wish - to give the impression it's firewood, gas cans, or?..:h:h
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
