newrver327 wrote:
This is a update on my question, Looking at 5vrs. My truck is a 2009 duramax CCSB. The door sticker for gcvw 9200#,it has 3.73 gears, and it weighs approx. 6850# with a half tank of diesel and driver. By the time I add more fuel,another passenger and the hitch it leaves me with 1700# for the pin weight and all the extras I would also be adding.
What size tires are you running?  If you've got the OEM 245/75R16 like mine is spec'd for, then jump up to 265's.  You'll pick up about 900 lbs of tire capacity, which =should= put you over the RAW number.  Frankly, if your pin puts you a bit over total payload, but under RAW and tire capacity, you'll be fine.  Might want airbags to level things out, though.
Lyle
