alexleblanc
Apr 07, 2016Explorer
Jim102 wrote:
Goducks,
We have decided on go with the F250, the less we have to worry about, the better.
Anything special we should get, or is the base model enough?
Thanks for the help,
Jim
pretty much every and any configuration of the F250 or SRW F350 will pull that fifth wheel without issue - the big difference will be if you opt to go Diesel or not - my suggestion would be either a Gasser with the 4.30 gears or a diesel for slightly better performance however the gasser with 3.73 will be acceptable too. They simply need RPM's.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
