allendlung wrote:
What are other good years of dodge trucks?
What should I look out for. I'm guessing I need to expand my budget, that's fine. I just want something that will last a long time.
You should make it clear if you want 2WD or 4WD.
If you do not mind smog check every two years, then a 1998 or newer is good. If you do not want smog, then you want 1997 or older.
Exhaust brakes on automatics in their stock form do not work until 2003 (I think). A torque converter upgrade is required and 60 lb exhaust valve springs are required pre-2003, as I recall. The torque converter must be able to lock up, and if so, the valves are subject to float without the 60 lb exhaust valve springs.
The 1995 through 1997 and 1st half of 1998 do not use a computer for fuel, it is mechanical. Unlike the mid 1998 and newer do not have issues with the lift pump or injector pump.
I have had my 1996 since 2001. It is 2WD, and last time on the dyno I was at 250 hp. I get 17 to 19 MPG empty, and 12.5 to 13.5 with my 4000 lb TC. I have the mods above, and a less than year old $4,500 transmission with a triple disc converter. My 1996 is setup for 5th wheel, TC and TT. It has a U.S. Gear exhaust brake. It has been my pride and joy, with a list of modifications too long to list. I post this to suggest I am far from a stranger to the 5.9.
OI really like my new to me 2004.5 DRW Quad cab due to its creature comforts, but in it's stock form it does not hold a candle to my 1996, power or MPG wise.
