time2roll
Jun 19, 2023Nomad
mrad wrote:
I will usually set the temp at 74 in the morning when the the outside temp is under 73 With the fan set on high.
Any other advice?
Set the thermostat at 68 overnight and keep it running 24/7. Get another bed cover if needed.
Vents closed unless you have just arrived with the interior at 100+. Close the vents when the sun sets.
A/C with a wall thermostat will have a freeze sensor to cycle the compressor. Sometimes these fall away from the evaporator allowing freeze up. Get in there and check it. Access by removing the inside cover.
While the lower cover is off check the plenum divider is properly positioned and sealed to direct all air to the ducting vs circulating internally. Poor installation methods are common. Get some tape and fix it.
Try not to park broadside to the sun. Any shade helps too.
About Fifth Wheel Group
