dustyniel's avatar
dustyniel
Looking for Advice!
Hello everyone, I am new here and planning to buy a 5th wheel toy hauler in the near future. It will be my primary residence for the next 5-10 years, looking at 30-36 length. Asking for any advice / tips on what to look for prior to purchase to avoid buyers remorse.Thing I already know I want: 50 AMP service, dual Slide outs, Dual A/C, Separate garage area w/patio door separating space, queen size bed w/nightstands, full size fridge, entertainment center area, tub/ shower area- NOT a corner unit, pass through storage underneath, outdoor cooking/ entertainment area. Planning on a 3/4ton truck to pull trailer with motorcycle inside. Helpful advice / suggestions are welcome. Thank you
  • I am on my third toyhauler. The first was a 27 foot Weekend Warrior bumper pull, had that about three years. Moved up to a 35 foot Cyclone 5th wheel, had that about three years and was disappointed with the build quality of the unit and the attitude of the manufacturer (Heartland). Replaced the Cyclone with a Voltage 3200 in 2011. Still have that trailer. It has been towed over 30,000 miles. I have a 2015 GMC 3500 crew cab dually which replaced a 2003 Silvarado 2500 HD, both diesels. Given the requirements you described I don't think you will find a toyhauler shorter than 35 -36 feet long, and will probably need to look at 38 foot and longer 5th wheels. You will need a 1 ton truck, and probably a dually. Trailers are almost always heavier than the literature and the salespeople will tell you. I have found that putting toys in the garage will only reduce pin weight by 200 to 300 pounds, given the geometry of a 5th wheel toyhauler.
    Make sure that the trailer has adequate tires, axles and brakes for the projected load and plan on spending a lot of time performing upkeep and maintenance.
    Another factor to consider is how will you use the trailer, mostly in developed RV parks, or dry camping.
  • The way we shopped was to put down a list of must haves, and start shopping from that. Then you'll find some things you really like or want, so you add those to a second list. Should be narrowed down enough by then to be efficient shopping. Once you settle on a unit, then choose a truck.
    Your must haves sound like:
    1. Toy Hauler
    2. Bathtub
    3. Outdoor Kitchen
    4. Full Size Refrigerator
    5. 50A service
    The second AC can be added, and many units come pre-wired, so that wouldn't be a must-have. Queen bed is virtually automatic in a rig that meets the other things.
    Your must-have list will greatly restrict the units you are interested in because they are all space eaters. My guess is that they will drive you up in length more toward a 37ft or longer rig. The bathtub alone might drive you into a massive rig, so if there is one thing you can give up, that would be it.
  • Hello,
    A 3/4 Ton truck will not work for the 5th wheel you are looking for. I have a 31 foot 5th wheel that I tow with a 3/4 Ton diesel truck. If I go any bigger I will need a 1 Ton diesel truck.
    As was stated find the 5th wheel you want and then buy the truck to fit it. If you absolutely need the truck first, do not buy a 3/4 ton truck. You will have buyers remorse on the truck.
    Dave
  • TH and outdoor kitchen, not sure I have ever seen that. Outdoor kitchens seem common with families with children. With a TH you should have room to carry items for outdoor cooking.
