jerem0621
Mar 16, 2016Explorer II
Greetings!
Check out the Keystone Cougar line. They are decent quality and are a good value. They have everything from bunkhouses to rear living room models and everything in between.
Do you have the OEM gooseneck hitch or will you be adding one to your truck? If you have the Bulldog/Reese/hidden hitch, Curt, B&W then there are a lot of options.
Some RV manufacturers will void the warranty if you use a gooseneck adaptor on your trailer. But there are other options to pull your fifth wheel.
Thanks!
Jeremiah
Thanks!
Jeremiah
About Fifth Wheel Group
