laknox
Jul 02, 2019Nomad
nykolas$$$Rain3345 wrote:
as far as protecting the general roof surface I am using an Amazon purchased "Gel-Gloss RV Wash and Wax " it was rather dirty and so I am planning to give it a second March but is there really enough wax in this to properly protect the roof or should I be giving some sort of additional treatment.
I've never been on the roof of a new 5th wheel mine seems to be rough what is the proper texture or feel should the roof be?
thansk
I've never heard of anyone using wax on their roof. Basically, use a mild detergent (Spic-n-span was the go-to for a long time) and a soft brush and just clean the roof off and rinse it. Inspect the caulking and use some self-leveling caulk like Dicor to seal them. If they're really bad, then scrape off the old caulk, prep the surface and re-seal. For any holes, suspected holes or scrapes on the roof surface, use some Eternabond, or similar, tape. Again, prep the surface and roll it down after sticking. It's pretty well permanent, so don't put it where you don't want it. :B I read about people who've bought a brand new rig and Eternabonded virtually every seam on the roof! :B
x2 on the tank info. Don't believe the indicators. Don't leave the grey and black tanks open to drain. Wait until near-full, then drain; black first, using the on-board flush or, if no flush, a clear elbow that has a hose attachment that allows you to back-flush. Grey water after black. Use as much water as you can when using the bathroom. Helps liquify the solids and clean out better.
Lyle
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
