Brodie3Az
Sep 15, 2013Explorer
Hello RedRocket204,
The name brands are prefferable due to proven product history. The low cost off brands have not had a chance to show how they can stand up to use and punishment.
2-stroke motors have been on the way out and are more sensitive to changes in elevation and require tweaking when traveling.
Fuel Injection is the in-thing for the ATV's nowadays. Those having prior experience with carbuerated motors report that the FI models are able to compensate for elevation changes.
Power steering is new to the ATV world. I have not had experience with it, but like an automobile it might be helpful if stuck, not moving, and trying to turn the front end.
Independent rear suspension - Smooths out the ride tremendously.
Take a mirror to allow viewing the underside of a vehicle that is for sale. look for dents, creases, bends in the plates and tubes.
Check compression for excessive engine wear.
You can always require that the unit be inspected at the local dealership.
Good luck to you in your search.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
