soren
Nov 29, 2016Explorer
You might have to install an exposed backer board. This involves making a nicely finished board that span the entire area where the hand rail will be mounted. I have done then in 3/4" Oak with nicely routered edges and a nice stain and urethane finish. This board is screwed to anything and everything that's structural in the wall. It then becomes the mounting surface for the hand rail brackets. You may have seen something similar in public bathrooms, as it's a common technique for securely mounting handicap grab rails to an existing wall, where studs do not end up in places that would be suitable for mounting the bar, and there is no blocking installed inside the wall, between studs.
In another case, I built a custom handicap entrance rail for our motorhome. It is a complicated affair made of 1/2" black steel gas pipe, bent with a conduit bender. The railing is attached to the floor with pipe "floor flanges" and the upper end is welded to a piece of 1/8" thick steel flat stock that spans from a window flange to a door flange, where it is securely screwed tight.
About Fifth Wheel Group
