4x4ord
Sep 04, 2019Explorer III
usmc616 wrote:
Hi all, I currently tow a TT but am looking to get a fifth wheel. My questions are about "pin weight". My current TV is a 2004.5 Ram 2500 with the HO 5.9 Cummins rated to tow 13,050lbs. GCWR is 20,000lbs ( I found this on several tow guides), GVWR is 9,000lbs ( from label on door) and curb weight is 6727 lbs ( from same label on door) but weighed 7540 on scale( full tank of diesel, 140lb driver, cap on bed and tool box in bed) . My truck is a 4x4 with a 6' 3" bed.
With the above info I am trying to find out what will be my limiting factor when looking at fifth wheel campers. If I understand it correctly I should estimate 15-20% of the fifth wheel GVWR to be my pin weight, is that correct??Iif so then I only have 1490lbs available of pin weight? ( GVWR- Curb weight) is that correct? Educate me please
Many 3/4 ton owners ignore the GVWR of their truck and use the rear axle rating as their limiting value. If you where buying a truck to use for a fiver I'd say get a 1 ton SRW but because you've already got a truck I'll say ignore the GVWR and let your rear axle rating determine your maximum pin weight.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 15, 2026
