RanduExplorerFeb 06, 2016Loose toilet--Floor mounting flange cracked.Toilet loose from floor so removed and discovered that mounting flange has cracked in a few places. Unscrewed flange from floor and found that it's glued to drop pipe. I can see glue from flange taper...Show More
TwomedExplorerFeb 07, 2016Reinforced with JB Weld and you should be good to go...so to speak. :) :) :)
Related ContentCracked Torklift Mount - DisappointedCracked motor mountImmigration crack downNew floor and the ToiletCracked tires
