Carl_n_Susan
Sep 11, 2016Nomad II
This is a common problem for some rigs with overflow tubes down under the frame. The sloshing of the tank as you move down the road causes water to exit via the overflow tube. Once it does, it starts a siphon effect draining the rest of the water down to the level of the pickup in the tank.
Some have relocated the overflow line so it terminates above the height of the fresh water tank. Others go for the shutoff valve which you have to remember to open when you start using the tank else you create a vacuum situation.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 26, 2025
