Buckeye_ChuckExplorer IIOct 20, 2014low point drains using antifreezeI din not open then recap the low point drains prior to running antifreeze thru the system. Should I have or is it not necessary when using antifreeze?
midnightsadieExplorer IIOct 20, 2014I open mine.some water could be in the system and dilute the anti freeze.
Related ContentHouse battery drainLow point drainsLow point drain troublelow points drainlow point drains with antifreeze
