rthibodaux wrote:
I have a 2010, 321 rlts Jayco eagle fw. First I live in south Louisiana. There are 2 low points drains, one by the battery compartment and one close to the front door. I never had to use them , so my question is what does it drain. There are no valves at the end of the tubing. So why are they there and if its a low point drain where do I drain them. I living up to what they told me years ago, there is no such thing as a dumb question, but I beginning to wander.
thanks
Look in the basement on each wall low near the door . Two covers about 3x5. Take the screws out and there is the valves. If it's like my 2011 321rlts ,looking in 3 on left & 2 on battery side. The two on bat side drain washer connection & 3 on left everything else. I also have cutoff valves on the water lines to the washer in ceiling of basement..
Your fresh water tank drain is next to rear tire on drivers side.
