Texas_Two_Stepp
Jul 19, 2013Explorer
This may not answer your question, but here is my input. My rig is about 2-3 inches nose high with 8" of clearance. I have around 6K on each axle and well within the axle rating on each axle. My pin weight is also good.
You have 7" clearance which is good. 6" is usually the accepted minimum. If you are ok on your weights i wouldn't worry about it.
How nose high are you and what is your concern?
About Fifth Wheel Group
