94-D2
Jun 17, 2020Explorer
Chances are the inside stove is a low pressure and outside is a higher pressure appliance. This results in lower and higher BTU output. Answer for inside Is a smaller percolator, or just heat it on the outside stove. This is normal for most RV’s. Probably not a plug or restriction. If you have even flame inside, with proper even flame color, you burners are fine.
About Fifth Wheel Group
