C Schomer wrote:
My last several trailers have had 6K axles, and I will only use 16 inch LT tires. One manufacturer told me that ST tires are not built to the safety standards that any tire for carrying passengers are. Craig
I agree with above, but all ST tires are not created equal. I replaced my 8yo Providers last Summer, with another set of same. Here is a description from e-trailer. "Provider radials are constructed with double polyester cords and double steel belts for increased durability and endurance. A protective layer of nylon is wrapped around the steel belts to help prevent tread separation. Provider radials are bake tested - a process usually reserved for automotive tires - to ensure that the rubber holds up over time."
Also from e-trailer "Provider radial with automotive-grade tread"
speed rated 81 mph
These came OEM on my FW and gave superior service. They are available in many sizes/load ranges.
Jerry
