The axle spacing on my 2013 Silverback will not allow LT's to fit. As a matter of fact I found 14 ply ST's and they will not fit. I went with a Maxxis ST. Anyone run into this alxe spacing thing? Two...
Dexter axle recommends one inch minimum between the tires.
My last 27' 5er has 5/8" gap on one side and 7/8" to 1" on the other. Ran the first set of LT245/75-16 E tires for 48k miles and was about 20k into the 2nd set and wife says its time to upgrade the trailer.
Sailun has a ST235/85-16 G at 31.7" and a ST235/80-16 G at 30.8" both at 4080 lbs capacity. These tires are a all steel ply carcass commercial grade tire.
