tko9900
Jun 29, 2016Explorer
LT Tires
The axle spacing on my 2013 Silverback will not allow LT's to fit. As a matter of fact I found 14 ply ST's and they will not fit. I went with a Maxxis ST. Anyone run into this alxe spacing thing? Two...
fj12ryder wrote:tko9900 wrote:The max pressure for the "G" rated Sailun tire is 110 psi. That doesn't mean you have to run them at that. If you are carrying less than the maximum load then you can run less pressure. I run mine at 90-95 psi. I'm running a max weight of 2500 lbs./wheel.
fj12ryder JIMNLIN What is Sailun inflation pressure? I thought I saw 110 psi. Are wheels stamped or rated for max psi? 1 inch between wheels, seems really close.
ol Bombero-JC My wheels are stamped 6", tire dealer would not put 245's on my wheel.
The capacity of your wheels is probably stamped into the wheel on the back side, that's where mine was.
