medic_66's avatar
medic_66
Lube me up....
Hi everyone. I just got everything ready for the summer and squirted some slider seal lubricant on my outside seals on the slide out and checked all the lights and yada yada yada to get ready for the summer.
Here is my question...what kinda of lube are we supposed to squirt on the slideout parts on the unit that move the room? Regular WD-40 work?
Thanks,
RC
  • WD 40 is not actually a lubricant it is for water displacement and rust prevention
  • I use a dry lube called Slip Plate... I already have it on hand for my SuperGlide so for me I always have some handy... Never use a lube that can attract dirt and grime....Joe
    Thanks,
    RC
    You don't want to use WD40 as it may attract dirt. Use a dry type lube and don't lube the hydraulic ram part just the rails with teeth and gearing.
    Good article on slide maintenance - http://blog.goodsamclub.com/2013/05/the-rv-doctor-correct-care-maintenance-of-your-rv-slideout/
    Cheers Ray
