clotusExplorerFeb 08, 2016lubing axleI have Dexter EZ-Lube axles. Per Dexter they need to be lubed once a year or 12k miles. I am at my year mark. I have a boat that requires lubing several times, but has a cap that pushes out letting...Show More
AllworthExplorer IIFeb 08, 2016Of course, if you have Dexter disk brakes, it is NOT necessary to pull the hub.
Related ContentE-Z Lube AxlesEZ Lube axles/hubsDexter Easy Lube axlesAnnual Brake Inspection and Axle Re - Lube (Pic's)E-Z lube axles
