clotus
Feb 08, 2016Explorer
lubing axle
I have Dexter EZ-Lube axles. Per Dexter they need to be lubed once a year or 12k miles. I am at my year mark. I have a boat that requires lubing several times, but has a cap that pushes out letting...
azjeffh wrote:
What does Dexter suggest about checking your brakes? Since the hub must be removed to do it, a front bearing pack/inspection is worth the little extra effort. Since you did the front bearings, why not the rear along with new seals?
See, no need for EZ-Lube :) BTW, I also have them on my trailer and found them to be useless.
