- lawaco12Explorer IIwould be nice if all would put fittings on them. my 5th must have built on Monday I have less than 50 trips and have had both original seize what happens the jack screws seize in jack nut. have taken them apart but have never been able to break them loose so that's why I want to find a way to grease them. if you have ever had one apart you would see that there is no way to lube other than taking apart that's 3 or 4 hour job hope everyone understands what im talking about. its a lot of time and money when one goes bad and you cant buy the jack screw and nut have to buy the assembly
- AlpenliterExplorerI had one snap way back in the boondocks outside of Moab. Yea, they do break. Anything with gears needs lube eventually. UltraFab just started making them with Zerk fittings according to the latest RV Travel Newsletter.
- h2guyExplorer13 yrs, 667 campsites, 2945 pin weight, never messed with them, they just work.
- sheltieRVExplorer
lar5camping wrote:
What?
I never heard of lubing landing gears! :R
My legs have Zerks on them, they were squeaking at one time and after lubing them, quiet once again.
- lar5campingExplorerretract the landing gear, block the wheels.
Liberate the shnopenstool from the kstew bracket.
What?
I never heard of lubing landing gears! :R - B_O__PlentyExplorer III read you can just take the top cover off and pour in some motor oil. It will run down and lube everything. Makes perfect sense to me...
B.O. - AllworthExplorer IIDrill a hole in the housing; get metal fragments in the gears; and.......
- donn0128Explorer IIThe screw is so far in it would take a couple if tubesod grease to get any where. Taking the leg apart is simple to do.
- raygregExplorerit is a shame that they don't put grease fittings on the jacks. Sorry I don't know the answer to your question
- lawaco12Explorer IIno I just want to lube the screw trying to get trailer on truck but screw is making loud squeaking noise. had one to lock up and had to buy new assembly just hoping to avoid that again
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
