DR_Buck
Apr 25, 2013Explorer II
rrupert wrote:
This may be a long shot, but did you check the emergency breakaway switch to make sure it isn't messed up in some way?
Not possible. The Max Brake gives you a message on the screen that tells you what is happening. Mine had no display at all, which is a fault in it's self as the screen should only be blank if the trailer is not connected. Then when the screen did light up, the message said "Parking Brake Set". I'm 99% sure the controller is toast!
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
